Just replaced thermistor (tested bad), belt & idler puller. First the drum light comes on when I plug it in. Second it poems on but when I hit start it beeps 3 times & does nothing. Any suggestions?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Are you receiving any error codes? What happened that caused you to replace those parts? In other words what were the symptoms before?
The washer was noisy when running and it just stopped. A guest at my house said they saw F1. When I checked it I couldn't get a code. Did a little research and decided to check thermal fuse & thermistor. Fuse checked ok but thermistor checked bad. Also when I opened it the belt just fell off. Saw that the idler pulley & belt where in bad shape. Replaced thermistor, pulley & belt, reassembled. At this point I noticed the drum light came on when I plugged it in & wouldn't run. Rechecked wiring I had the two hands session reversed. I corrected this and the dryer is running better than ever. Again thanks for the response.
