effortjb
#1 Posted : Wednesday, August 10, 2016 1:20:49 PM(UTC)
effortjb
Just replaced thermistor (tested bad), belt & idler puller. First the drum light comes on when I plug it in. Second it poems on but when I hit start it beeps 3 times & does nothing. Any suggestions?
brobriffin
#2 Posted : Wednesday, August 10, 2016 2:08:44 PM(UTC)
brobriffin
Man
United States
Are you receiving any error codes?
What happened that caused you to replace those parts? In other words what were the symptoms before?
effortjb
#3 Posted : Wednesday, August 10, 2016 4:40:50 PM(UTC)
effortjb
The washer was noisy when running and it just stopped. A guest at my house said they saw F1. When I checked it I couldn't get a code. Did a little research and decided to check thermal fuse & thermistor. Fuse checked ok but thermistor checked bad. Also when I opened it the belt just fell off. Saw that the idler pulley & belt where in bad shape. Replaced thermistor, pulley & belt, reassembled. At this point I noticed the drum light came on when I plugged it in & wouldn't run. Rechecked wiring I had the two hands session reversed. I corrected this and the dryer is running better than ever. Again thanks for the response.
