jmullins68
#1 Posted : Monday, February 18, 2008 5:25:31 AM(UTC)
jmullins68
The dishwasher is blinking all lights in the mode section except sensing and also says a 6 hour delay is set (I did not set that). When I switch off/on the breaker all lights return to normal but at the first attempt to run a load the same thing happens. I can hear it try to cycle on something but it just stops after a short time. No buttons work at all and I've gone all thru the trouble shooting section. Any guidance would be greatly apprecaited.
#2 Posted : Monday, February 18, 2008 2:16:15 PM(UTC)
Most likely the problem with your dishwasher caused by one or more stuck pads on the key pad which has to be replaced.
- The part number for the key panel is AP3211387
