The dishwasher is blinking all lights in the mode section except sensing and also says a 6 hour delay is set (I did not set that). When I switch off/on the breaker all lights return to normal but at the first attempt to run a load the same thing happens. I can hear it try to cycle on something but it just stops after a short time. No buttons work at all and I've gone all thru the trouble shooting section. Any guidance would be greatly apprecaited.
Most likely the problem with your dishwasher caused by one or more stuck pads on the key pad which has to be replaced. - The part number for the key panel is AP3211387 Gene.
