NGW1031982
#1 Posted : Wednesday, July 27, 2016 7:39:09 PM(UTC)
NGW1031982
I am guesstimating on the age of the dryer.
The dryer now sometimes drys clothes, and other times it won't. It doesn't matter on the size of the load.
There are no obstructions of air, and the exhaust was cleaned out as well.
When I took the cap off to view the flame during a run, I noticed that after a while the flame goes out and then there is a soft orange glow that phases on and off for the rest of the cycle.
It seems that there is a problem with the gas staying on.
I took some readings on the temperature sensors, and thermal fuse, and they seem fine.
I took some readings on the gas coils, and am not sure about the results.
On the two terminal coil, I got 1268 ohms.
On the three terminal coil, I get 1936 ohms between common and terminal two. Between common and terminal three, I am getting 566 ohms.
What do you all think?
brobriffin
#2 Posted : Thursday, July 28, 2016 6:36:14 AM(UTC)
brobriffin
Man
United States
Your readings on the coils are within the parameters however the 1936 is at the top end of the scale. Good readings on the coils are inconclusive at times. If you see the igniter glowing on and off with no ignition try first to replace both coils.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
If this doesn't solve the issue then the gas valve itself likely is bad and will need replaced.
Whirlpool WP8318277 Valve, 60 Hz. (includes Pipe & Illus. NO.7) - AppliancePartsPros.com
