I have replaced the thermistor and the thermostat for my dryer and still getting error code ts on the screen. I have also made sure the vents are cleared. Are there any other parts that could cause this error code except the main control board? I would appreciate any help :)
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
tS = thermistor error. Check to see if the new one is showing 10K ohms at roughly 77 degrees. Try checking for that resistance from the wiring at the main control board. See your wiring chart for the connection number and wire color. It should be something like CN6. If you get a true reading there then I suspect an error in the main control board.
