soshea42
#1 Posted : Sunday, July 10, 2016 4:10:09 PM(UTC)
soshea42
I have a Frigidaire washer dryer combo and the washer isn't working. It fills with water, but when it is supposed to agitate or spin is just makes a humming noise without any action. I have replaced the belt and the door safety latch. I am not sure the timer is bad because when I move it manually, the washer will drain, just not agitate or spin when it is supposed to. Any suggestions?
Thank you.
Shaun
brobriffin
#2 Posted : Tuesday, July 12, 2016 3:46:19 AM(UTC)
brobriffin
Man
United States
One of two things are possibly at fault. The start capacitor Frigidaire 131212301 Capacitor - AppliancePartsPros.com may be bad. It should test out between 233-280 MFD. If it tests ok then the motor Frigidaire 134159500 Drive Motor - AppliancePartsPros.com is likely your issue.
soshea42
#3 Posted : Wednesday, July 13, 2016 5:15:42 AM(UTC)
soshea42
Thank you for your reply. I had a spare start capacitor and I was able to replace it quickly. It fixed the problem.
Shaun
