I have a Frigidaire washer dryer combo and the washer isn't working. It fills with water, but when it is supposed to agitate or spin is just makes a humming noise without any action. I have replaced the belt and the door safety latch. I am not sure the timer is bad because when I move it manually, the washer will drain, just not agitate or spin when it is supposed to. Any suggestions?
Thank you.
Shaun
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Thank you for your reply. I had a spare start capacitor and I was able to replace it quickly. It fixed the problem.
Shaun
