AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer makes loud rubbing and now banging Noise
Have an LG Front Loading Washer. Works perfect until the spin cycle starts. Sound like tub is grinding against something. In the last couple of days it starts with a grind and now is banging very loudly. Inside drum seems to be stable with no extracurricular movement. I am afraid to continue using it. I have a little experience at this but not with this make and model. Can anyone help?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Also I would recommend if you have to replace the spider to go ahead and replace the bearings while you have it apart. Helps not having to repeat steps later. Just my opinion.
Washer Repair
