Hello, I have a GE GFWH2400L0WW that stopped spinning and agitating. I found directions to get into diagnostic mode and found the following codes. SU1 SP6 EU1 EP6 1P6 30 IC
I didnt see any of those listed on the directions to access diagnostic mode. Any help would be appreciated.
I have the same GE GFWH2400L0WW. My washer stopped spinning fast. I did the ramp up test and spin test and it worked fine. I have the same codes as EJGluck, but mine had more info after 4 of them:
SU1 1:09 SP6 5:17 EU1 1:17 EP6 5:20 IP6 30 1c
IS there anywhere I can look these up?
Thank you! :)
I got the same results, I realized on my washer t02 gives you the version info, for the error codes go to t01
