display does not flash..does not show error code...all numbers display...and stay lit.
coincidently,my furnace went out same day.. repairman replaced control board.
left power off full day..did not solve problem..
any suggestions?
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
Hi Phillip, If you've tried to push the "cancel" or the "clock" buttons and it did not help then the control board has to be replaced. - The part number for the control board is AP2633034 - The part number for the overlay (clock plate) is AP2025221 Here are the break down diagrams for the GE range Model JSP26BW3ADGene.
thank u gene for prompt reply...I pulled up the part number and it says a qualified tech might be needed...due to some model changes..should I try this myself?? I do not fear any plumbing job,(i can always take a shower..electricity is another matter...
phil
Phil,
I would recommend to order the part first. In most cases it comes with the installation instructions. If not, you can call a tech later and still save on the part.
