phillip melton
#1 Posted : Sunday, February 17, 2008 2:38:58 PM(UTC)
phillip melton
display does not flash..does not show error code...all numbers display...and stay lit.
coincidently,my furnace went out same day.. repairman replaced control board.
left power off full day..did not solve problem..
any suggestions?
#2 Posted : Monday, February 18, 2008 12:39:17 PM(UTC)
Hi Phillip,
If you've tried to push the "cancel" or the "clock" buttons and it did not help then the control board has to be replaced.
- The part number for the control board is AP2633034
- The part number for the overlay (clock plate) is AP2025221
Here are the break down diagrams for the GE range Model JSP26BW3AD
phillip melton
#3 Posted : Monday, February 18, 2008 3:16:40 PM(UTC)
phillip melton
thank u gene for prompt reply...I pulled up the part number and it says a qualified tech might be needed...due to some model changes..should I try this myself?? I do not fear any plumbing job,(i can always take a shower..electricity is another matter...
phil
#4 Posted : Monday, February 18, 2008 3:25:47 PM(UTC)
Phil,
I would recommend to order the part first. In most cases it comes with the installation instructions. If not, you can call a tech later and still save on the part.
