Ralphy58
#1 Posted : Monday, June 27, 2016 7:47:31 AM(UTC)
Ralphy58
Upper(convection) oven not heating up.
Lower (regular) oven works fine.
Digital display working fine, but when I try setting upper oven temp to, say, 350 degrees, temp display remains at 100 degrees and oven elements are not heating up.
No error messages on control panel display
Have replaced oven sensor and high limit thermostat, and checked continuity in both broil and bake heating elements.
Could issue be bad control switch or relay module?
Ralphy58
#2 Posted : Monday, June 27, 2016 7:52:42 AM(UTC)
Ralphy58
Frigidaire electric double wall oven will not vent blower motors do not run on top o (Oven Repair (including Ranges and Cooktops))
by gio 3/28/2012 9:04:54 AM(UTC)
Electric Double Wall Oven Amana (Oven Repair (including Ranges and Cooktops))
by peterluong 2/24/2009 10:23:14 AM(UTC)
Electric Double Wall Oven Warm, not Hot (Oven Repair (including Ranges and Cooktops))
by jcrump55 11/11/2007 11:55:21 AM(UTC)
GE Electric Double Wall Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by tjp 10/27/2007 8:06:52 AM(UTC)
