icemaker not working replaced ice maker still not working replaced water pump still not working checked water it is fine any ideas?
Here are a few steps you can take to get your ice maker working. 1 Check the water supply line.
2 See if the fill tube is frozen.
3 Look inside the ice mold.
4 Check the water line
5 Check the tap valve
6 Check the solenoid.
For more information visit: Oakville Home Appliance Repair Services | Certified Expert
