Hi Everyone! Samsung dryer Model DV42H5600EW Heater Element Part number is DC93-00154A. So my father thought it would be a good idea to try to fix his dryer by himself! Dryer would not heat. Took the whole dryer apart removed the heater elements & all of the wires that go to it. He did not take a picture or write down what order they belong in. Turns out the heater elements are OK!
Now I need to know where the wires connect! There are three (3) wires that connect to this heater element & four (4) wires that would connect to the thermal cutout & the high limit. The (4) wires for the thermostats are pretty much self explanatory! The (3) wires for the heater element is where I'm having a problem! I believe there is a white-red-blue wire set that connects to the element. I'm guessing it's important to know the proper placement because the element is a dual element. Can someone here PLEASE HELP?
So over 40 views but not one reply! Looked on youtube for this information & every video is for the 2 wire element. Does anyone have any info on this or maybe a wire diagram? Thanks!
