maroma
#1 Posted : Tuesday, May 24, 2016 6:01:36 AM(UTC)
maroma
I have a general monogram side-by-side-by-side refrigerator. the LED (in the ceiling) on the fresh side doesn't come on when the door is open. I replaced the LED panel with a new one yesterday and still doesn't come on. any ideas? all of the other lights come on without any problems
MarkusC
#2 Posted : Tuesday, March 7, 2017 8:49:50 AM(UTC)
MarkusC
I had a bad transformer mounted under the frig. Hard to get to. You have to pull down a whole electric box in the center (6 screws) and then there are two screws holding the transformer up. Before buying a new transformer check the voltage on the input side. Should be 120V. Should be something like 20V on the output side. If input side ok but output only, say, 1 volt, the transformer is bad.
