Our Amana Oven Door not closing because a sort of nigh or a latchet "J" shaped that mounted on the oven (not the door side) is stuck and is not sliding to the opening on the door side
Someone knows how to fix it or what is the problem ?
Thank You
Might have to replace the latch. Was it self cleaned recently?
