Longwolf
#1 Posted : Wednesday, April 6, 2016 5:03:08 PM(UTC)
Longwolf
Hello all,
My Frigidaire gallery ice maker chute door is not closing all the way, which causes frost to build up/clog the dispenser, and water/condensation drips into the drip tray. I just replaced the rotary damper and chute door spring, but after reassembly, if I shine a flash light up the chute, I can see light coming through if I look down from inside the door dispenser. Grrr!
What parts next should be replaced? The ice door bracket looks fine, and the rubber seal/insulation is clean and seems fine. But the door just won't shut all the way, leaving 1/8" open on just one side:
UserPostedImage
Also, in case someone has the same problem, there is a great video on how to disassemble the chute door here: Frigidaire 241688401 Ice Door Bracket - AppliancePartsPros.com
Thanks!
CJ
Longwolf
#2 Posted : Tuesday, April 19, 2016 12:49:44 PM(UTC)
Longwolf
FYI, I replaced the rubber seal and it fixed the problem. I read that over time they start to lose their flexibility.
Appliance Medics
#3 Posted : Tuesday, April 19, 2016 1:04:22 PM(UTC)
Appliance Medics
Glad you were able to solve it!
Guest (4)
