Dryer fails to completely dry a load on the automatic setting. It also takes an unusually long time to completely dry on the timed setting. It appears to heat up but only on low heat.
Turn unit on and go out side and feel the vent it should feel like a hair blow dryer. not heat wise but air flow. Is the #1 cause of long dry times. Also if thats not it and the unit is gas. Then i would bet secondary coils on gas valve are not opening
