Frank Barry
#1 Posted : Tuesday, April 5, 2016 9:35:25 AM(UTC)
Frank Barry
Dryer fails to completely dry a load on the automatic setting. It also takes an unusually long time to completely dry on the timed setting. It appears to heat up but only on low heat.
Alexkourelis
#2 Posted : Thursday, April 7, 2016 4:19:32 PM(UTC)
Alexkourelis
Turn unit on and go out side and feel the vent it should feel like a hair blow dryer. not heat wise but air flow. Is the #1 cause of long dry times. Also if thats not it and the unit is gas. Then i would bet secondary coils on gas valve are not opening
