My microwave is acting funny. The keypad has stopped working, fan comes on by itself, and some type of alarm beeping. I replaced the "Electronic Control Board" Part Number AP4299761 but that did not fix the problem. Now after I reset the microwave, the display lights up and ask "Do I want to set the date", but the keypad does not work and it will eventually display "Error: Code - F9.Q". Anybody have a suggestion?
JD Ford
I am experiencing the same exact symptoms. Has any one successfully repair this issue. F9.Q
F9.Q Fault Code I am having the same symptoms as someone else has posted I do not see ant reply's to his post as to the suggested repair.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My microwave is showing Error: Codd-F9.Q
Rank: Guest
