JDFord
#1 Posted : Monday, April 4, 2016 6:25:26 AM(UTC)
JDFord
My microwave is acting funny. The keypad has stopped working, fan comes on by itself, and some type of alarm beeping. I replaced the "Electronic Control Board" Part Number AP4299761 but that did not fix the problem. Now after I reset the microwave, the display lights up and ask "Do I want to set the date", but the keypad does not work and it will eventually display "Error: Code - F9.Q". Anybody have a suggestion?
JD Ford
tfilides
#2 Posted : Wednesday, July 19, 2017 3:20:53 PM(UTC)
tfilides
I am experiencing the same exact symptoms. Has any one successfully repair this issue. F9.Q
tfilides
#3 Posted : Wednesday, July 19, 2017 3:26:46 PM(UTC)
tfilides
F9.Q Fault Code I am having the same symptoms as someone else has posted I do not see ant reply's to his post as to the suggested repair.
Guest
#4 Posted : Wednesday, June 22, 2022 12:55:37 PM(UTC)
Guest
Rank: Guest
Groups:
United States
My microwave is showing Error: Codd-F9.Q
Guest
#5 Posted : Wednesday, June 22, 2022 12:55:58 PM(UTC)
Guest
Rank: Guest
Groups:
United States
