roadrnnr
#1 Posted : Wednesday, March 16, 2016 5:32:16 AM(UTC)
roadrnnr
Cleaned screen, tested water pressure and did continuity check on inlet valve.
All OK
Will not fill to bottom of door, I think it is supposed to be about 3 inches above door bottom.
Could the water inlet valve still be bad or would the pressure switch be responsible for low water level?
Thanks,
