AppliancePartsPros.com
Appliance Repair Help
Washer Repair
frigidaire affinity washer not filling all the way??
Cleaned screen, tested water pressure and did continuity check on inlet valve. All OK Will not fill to bottom of door, I think it is supposed to be about 3 inches above door bottom.
Could the water inlet valve still be bad or would the pressure switch be responsible for low water level?
Thanks,
Washer Repair
