brokenge
#1 Posted : Thursday, February 18, 2016 2:32:59 PM(UTC)
brokenge
My potable dishwasher, GE model gsc3507p00ww, was taken apart and the pump and motor assemble was removed to replace the lower spray arm support. After reassembling, the dishwasher will not drain. the drain solenoid lever is engaging. There is no water making it to any part of the drain hose or chamber hose. There is no valve flapper on the chamber collection on this model. The dishwasher sounds as it should and the drain solenoid lever is engaging. I used a YouTube vid. https://www.youtube.com/watch?v=fnrqQxkgbOg as the motor looks the same as mine. I have cleaned all the parts and hoses. I can drain the dishwasher by hand depressing the drain solenoid lever while the drain hose is detached.
Joe / APP Team
#2 Posted : Friday, February 19, 2016 11:57:49 AM(UTC)
Joe / APP Team
Originally Posted by: brokenge Go to Quoted Post
My portable dishwasher, GE model gsc3507p00ww, was taken apart and the pump and motor assemble was removed to replace the lower spray arm support. After reassembling, the dishwasher will not drain. the drain solenoid lever is engaging. There is no water making it to any part of the drain hose or chamber hose. There is no valve flapper on the chamber collection on this model. The dishwasher sounds as it should and the drain solenoid lever is engaging. I used a YouTube vid. https://www.youtube.com/watch?v=fnrqQxkgbOg as the motor looks the same as mine. I have cleaned all the parts and hoses. I can drain the dishwasher by hand depressing the drain solenoid lever while the drain hose is detached.
Brokrenge, If you're sure the drain hose isn't kinked, clogged or obstructed, then you'll need to dismantle the drain solenoid assembly, use a small flat blade screw driver and remove the valve actuator arm Part number: AP4347034
You'll probably find that it is "rounded out" or cracked and is "slipping' on the drain flapper shaft.
Joe / APP Team
#3 Posted : Friday, February 19, 2016 12:04:20 PM(UTC)
Joe / APP Team
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
Dishwasher won't drain all the way (Dishwasher Repair)
by jennie_49031 4/9/2014 9:58:24 AM(UTC)
GE portable dishwasher won't drain (Dishwasher Repair)
by markj7777 3/18/2014 7:36:28 PM(UTC)
Frigidaire Dishwasher won't drain, fill, motor not running (Dishwasher Repair)
by Foofer 3/3/2014 10:13:05 AM(UTC)
