RepairKing53
#1 Posted : Friday, January 29, 2016 10:14:13 AM(UTC)
RepairKing53
Older Maytage dishwasher (probably 20 years old) suddenly stopped running. Door closes tightly but won't start wash cycle unless I manually push in and apply continual pressure to door. Assume its a door latch problem but seeking experienced advice. Do not want to sink cost of service call into such an old machine but door latch assembly is $31 and worthwhile if I can do myself. Appreciate any advice.
Joe / APP Team
#2 Posted : Friday, January 29, 2016 11:37:34 AM(UTC)
Joe / APP Team
RepairKing, Try this first, open the door, in the center of the tub opening, just inside and in front of the door seal, you should find a hex head 5/16 inch screw. use a socket or nut driver and loosen the screw a 1/2 turn or so, then slightly pull out on the latch hook Part number: AP4112973
then tighten the screw. You may have to make a few adjustments, but you want to be able to close and latch the door, and not have a leak(s) around, or at the bottom of the door.
RepairKing53
#3 Posted : Friday, January 29, 2016 12:49:47 PM(UTC)
RepairKing53
Joe, that worked like a charm. Thank you so much for the quick and accurate suggestion. First time I've used a forum and the service provided is much appreciated.
RepairKing53
Joe / APP Team
#4 Posted : Friday, January 29, 2016 1:00:52 PM(UTC)
Joe / APP Team
RepairKing53
RepairKing, You're Very Welcome !!! Glad we could help. Thanks,
