After the spin cycle, the washer makes a low humming noise which I am guessing is the drain pump still running. It never moves on past this. I just continue to hear that sound, and the clothes are always a bit more damp than usual. I have to manually turn the nob to the off position. Hopefully I am explaining this good enough. Any ideas would be great. Thanks! :)
It sounds like the timer is malfunctioning, shutting off the spin before it should be letting the pump continue to run.
The timer is listed as not available but I suggest you call APP and discuss the issue of a new timer with them. If they do not have one or a substitute look around at other sites. But try to get it from APP because you can return it if it does not fix the problem.
I will give that a try. Thank you so much!
