cfry
#1 Posted : Wednesday, January 27, 2016 11:20:23 AM(UTC)
cfry
After the spin cycle, the washer makes a low humming noise which I am guessing is the drain pump still running. It never moves on past this. I just continue to hear that sound, and the clothes are always a bit more damp than usual. I have to manually turn the nob to the off position. Hopefully I am explaining this good enough. Any ideas would be great. Thanks! :)
sidfink43
#2 Posted : Wednesday, January 27, 2016 2:10:52 PM(UTC)
sidfink43
It sounds like the timer is malfunctioning, shutting off the spin before it should be letting the pump continue to run.
The timer is listed as not available but I suggest you call APP and discuss the issue of a new timer with them. If they do not have one or a substitute look around at other sites. But try to get it from APP because you can return it if it does not fix the problem.
cfry
#3 Posted : Thursday, January 28, 2016 4:06:39 AM(UTC)
cfry
I will give that a try. Thank you so much!
