baronsc
#1 Posted : Monday, January 25, 2016 10:49:47 AM(UTC)
baronsc
This model refrigerator has a push button for removal of water filter located at the bottom grill. When I changed the filter this last time, the water would not shut off when I removed the filter and water continued to flow from the filter connection. Water flow stopped when new filter was installed.
Ice maker & water dispenser both continue to work when filter is in place.
Does this sound like the filter housing is the problem? I understand this is where the water should be stopped when the filter is removed.
Need help with a diagnosis of the problem!!
#2 Posted : Monday, January 25, 2016 11:53:56 AM(UTC)
Yes it does sound like a housing problem.
Click on the picture for more info about this part.
Part number: AP4369676
Be sure to mark which line goes where
