elearning.luna
#1 Posted : Sunday, January 24, 2016 10:53:51 AM(UTC)
elearning.luna
Hello! I accidentially unplugged my Maytag MHWE200XW00 washer while it was in cycle (the rapid wash rinse cycle, I believe). When I plug it in now, lights flash, but mainly it reads F1 E1 with three beeps. It is flashing the code and beeping continuously. I have the technical sheet and I ran the diagnostic test using the 3 button sequence, F1 E1 shows, but it won't allow me to do the automated test. Initially the door was locked, but I released it manually from through the bottom panel. There is no water in the unit, but I did have towels in there that could have soaked it all up. There is a clicking noise which I am to understand means that power is going to the CCU. Is there anyway to reset the computer?
sidfink43
#2 Posted : Sunday, January 24, 2016 1:49:14 PM(UTC)
sidfink43
Hard to say with this model but the most likely thing is that your sudden power shutoff damaged the control board and it needs to be replaced. You can return the board if it does not solve the problem and you have purchased it from this site.
