Dear all,
My freezer is working fine but the refrigerator is warm, both fans are working and i tried to turn the thermostat knob but no use, so help please what can i do? Thank you
Need a model number Find your model number - AppliancePartsPros.comAlso more info on the symptoms. What is the freezer temperature. Should be in the 0 to 5 degree F range. What is the frsh food section temperature. Should be in the 36 to 40 degree F range. What if anything have you done to troubleshoot this problem? |
THIS FORUM IS DEAD!!!!!!! |
