MRW2016
#1 Posted : Wednesday, January 13, 2016 5:23:32 PM(UTC)
MRW2016
Dishwasher failed with a leak detection indicator. Expected to find failed leak detection sensor but instead found moisture under the tub in the catch tray. Need some advice on potential causes?
Jeff / APP Team
#2 Posted : Friday, February 12, 2016 4:05:24 AM(UTC)
Jeff / APP Team
You will need to check all hoses on the unit and check the seals on the sump assembly. Also, check the water valve on the unit.
