Dishwasher failed with a leak detection indicator. Expected to find failed leak detection sensor but instead found moisture under the tub in the catch tray. Need some advice on potential causes?
You will need to check all hoses on the unit and check the seals on the sump assembly. Also, check the water valve on the unit.
