pcreson
#1 Posted : Friday, October 30, 2009 5:19:38 AM(UTC)
pcreson
My freezer is not keeping my food frozen, but the frig is staying cold. What could be the problem and how do I fix it?
#2 Posted : Saturday, October 31, 2009 3:14:57 AM(UTC)
Replacement parts for FRG FRS6R4EW1 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/240389616.pdf
Could be a defrost problem.
Remove the evaporator cover and check the coils, If heavily iced/frosted over you have a defrost problem.
Try forcing a defrost cycle, see the Note on Page one of the tech sheet.
If the heater comes on the your defrost board is shot.
If it does not come on then odds are high that it is either the heater itself of the defrost thermostat, both can be checked with a meter.
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
