Leo Ladzinske
#1 Posted : Tuesday, January 5, 2016 8:43:11 AM(UTC)
Leo Ladzinske
Upper oven works fine, lower oven will not heat. Please help with method to troubleshoot and repair. Thank you.
#2 Posted : Tuesday, January 5, 2016 9:59:36 AM(UTC)
Parts for KitchenAid KEBC278KSS04 Oven - AppliancePartsPros.com
See the attachment for the tech sheet
Could be that the oven shutdown thermal fuse for that oven blew.
You will have to remove power from the unit, pull the oven and check the fuse with a meter.
Leo Ladzinske
#3 Posted : Tuesday, January 5, 2016 2:21:48 PM(UTC)
Leo Ladzinske
The lower oven quit working a month ago and then after a week or so started working again. This time I turned the circuit breaker off for fifteen minutes and then turned it on. The lower oven did not come on. If the shut down thermal fuse is good what would be my next step?
#4 Posted : Wednesday, January 6, 2016 1:48:37 AM(UTC)
If it is OK then check the wiring to/from the elements.
If the unit shows that it is ready, check the oven sensor.
If all OK then odds are that tthe control board is bad.
Leo Ladzinske
#5 Posted : Wednesday, January 6, 2016 5:00:07 PM(UTC)
Leo Ladzinske
Could you help me locate a KitchenAid Technical Education Job Aid for my model,KEBC278KSS04. I located KAC-49 Job Aid 4317416 which is close to my model. I appreciate your help.
#6 Posted : Thursday, January 7, 2016 1:43:37 AM(UTC)
Sorry but I need more info about what you are looking for.
Kitchenaid Double wall ovens/ERROR F9E0 (Oven Repair (including Ranges and Cooktops))
by finzidad 12/15/2018 6:30:18 PM(UTC)
Loud Rattling Noises (FAN?) in KitchenAid Double wall oven (Oven Repair (including Ranges and Cooktops))
by curbalertband 6/27/2014 12:35:19 PM(UTC)
Kitchenaid double wall oven went dead during self clean cycle (Oven Repair (including Ranges and Cooktops))
by wentjr 5/22/2013 9:36:10 AM(UTC)
Kitchenaid Double Wall Oven Error E1-F2 (Oven Repair (including Ranges and Cooktops))
by iraslotnick 11/30/2008 10:27:15 AM(UTC)
