Redgateranch
#1 Posted : Sunday, January 3, 2016 7:44:11 AM(UTC)
Redgateranch
My stove takes forever to heat up to desired temperature, and usually have to turn it up 15-20 degrees to get actual temp I want. So if want 350 degrees, I turn to 375-380 and after 5 minutes it beeps that it is preheated but only at 200 degrees, then takes 20 or so minutes to get it to desired temp. No problems staying at temp.
