My stove takes forever to heat up to desired temperature, and usually have to turn it up 15-20 degrees to get actual temp I want. So if want 350 degrees, I turn to 375-380 and after 5 minutes it beeps that it is preheated but only at 200 degrees, then takes 20 or so minutes to get it to desired temp. No problems staying at temp.
