warnockb
#1 Posted : Friday, December 25, 2015 1:10:10 PM(UTC)
warnockb
when I push "BAKE," it displays "350°F," as before, but if you push the up-arrow button, the temp. setting only goes down
#2 Posted : Saturday, December 26, 2015 3:57:09 AM(UTC)
Parts for Whirlpool RBS245PDQ6 Oven - AppliancePartsPros.com
Have you tried unplugging the unit for several minutes to see if it will reset?
Problem is most likely in the control panel (keypad) or the control board.
It is more likely to be in the control board.
