when I push "BAKE," it displays "350°F," as before, but if you push the up-arrow button, the temp. setting only goes down
Here are your parts Parts for Whirlpool RBS245PDQ6 Oven - AppliancePartsPros.comSee the attachment for the tech sheet. Have you tried unplugging the unit for several minutes to see if it will reset? Problem is most likely in the control panel (keypad) or the control board. It is more likely to be in the control board. |
THIS FORUM IS DEAD!!!!!!! |
