My washer shuts off soon as i hit start button and you hear door lock activate it powers off. Any one have a idea what it could be? I think it may be door switch
Without a model number I can only give you a generic answer which is to look under the top cover or inside the lower service panel for tech notes that will tell you how to do some diagnostics and maybe generate some error codes. The door lock mechanism sounds like a likely cause.
11047511702 it is a kenmore HE2plus
Ok, good, the tech notes should be inside the lower service panel and they should enable you to test the door lock mechanism and the main board.
Originally Posted by: sidfink43  Without a model number I can only give you a generic answer which is to look under the top cover or inside the lower service panel for tech notes that will tell you how to do some diagnostics and maybe generate some error codes. The door lock mechanism sounds like a likely cause. I replaced the door switch it did not fix problem model # 11047511702. Still you turn on hit start wait a second you hear a locking sound then light comes on to show door lock then powers off. Can you help puzzled?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Have you pulled the tech sheet? If so did you run a diagnostics? Also see what error codes are coming up.
Originally Posted by: brobriffin  Have you pulled the tech sheet? If so did you run a diagnostics? Also see what error codes are coming up. How do I run that I cannot find my tech sheet.
Tech sheet in a plastic zip lock style bag, attached to the inside of the right or left wall.
Originally Posted by: brobriffin  Tech sheet in a plastic zip lock style bag, attached to the inside of the right or left wall. I looked and it is missing I think when they replaced the tub they removed it and I did not get it. Can you help me to walk through it to get it to run diagnostic to possibly get alarm. I have the manual but it does not show how to make it run a cyle to get it to run diagnostic?
note: the washer must be empty and the control must be in the off state before pressing the touch-pad sequence to start the test.
1. close the door.
2. select any one key (except pause/cancel) and follow
the steps below, using the same key (remember the key):
press/hold 4 seconds
release for 4 seconds
3. Upon release, all console led lights will turn on for 5 seconds.
4. If there are any failure codes, they will be displayed in the estimated time remaining display.
Note: this program recalls the most recent failure code first.
press the same key to advance to the next failure code.
(if the console doesn’t change then, the same failure
code was stored multiple times.)
if there aren’t any more failure codes, all the lights on the
console will turn on for 5 seconds.
Following this the washer will begin a diagnostic test, you may cancel if you wish by pressing the pause/cancel button.
