2 Pages12>
bowert
#1 Posted : Thursday, December 10, 2015 11:05:14 PM(UTC)
bowert
My washer shuts off soon as i hit start button and you hear door lock activate it powers off. Any one have a idea what it could be? I think it may be door switch
sidfink43
#2 Posted : Friday, December 11, 2015 11:10:41 AM(UTC)
sidfink43
Without a model number I can only give you a generic answer which is to look under the top cover or inside the lower service panel for tech notes that will tell you how to do some diagnostics and maybe generate some error codes. The door lock mechanism sounds like a likely cause.
bowert
#3 Posted : Sunday, December 13, 2015 10:23:16 PM(UTC)
bowert
11047511702 it is a kenmore HE2plus
sidfink43
#4 Posted : Monday, December 14, 2015 4:07:13 AM(UTC)
sidfink43
Ok, good, the tech notes should be inside the lower service panel and they should enable you to test the door lock mechanism and the main board.
bowert
#5 Posted : Wednesday, July 13, 2016 12:44:23 AM(UTC)
bowert
I replaced the door switch it did not fix problem model # 11047511702. Still you turn on hit start wait a second you hear a locking sound then light comes on to show door lock then powers off. Can you help puzzled?
brobriffin
#6 Posted : Friday, July 15, 2016 10:36:22 AM(UTC)
brobriffin
Man
United States
Have you pulled the tech sheet? If so did you run a diagnostics? Also see what error codes are coming up.
bowert
#7 Posted : Monday, July 18, 2016 11:24:27 PM(UTC)
bowert
How do I run that I cannot find my tech sheet.
brobriffin
#8 Posted : Tuesday, July 19, 2016 4:31:52 AM(UTC)
brobriffin
Man
United States
Tech sheet in a plastic zip lock style bag, attached to the inside of the right or left wall.
bowert
#9 Posted : Wednesday, July 20, 2016 8:15:04 PM(UTC)
bowert
I looked and it is missing I think when they replaced the tub they removed it and I did not get it. Can you help me to walk through it to get it to run diagnostic to possibly get alarm. I have the manual but it does not show how to make it run a cyle to get it to run diagnostic?
brobriffin
#10 Posted : Thursday, July 21, 2016 7:14:17 AM(UTC)
brobriffin
Man
United States
note: the washer must be empty and the control must be in the off state before pressing the touch-pad sequence to start the test.
1. close the door.
2. select any one key (except pause/cancel) and follow
the steps below, using the same key (remember the key):
press/hold 4 seconds
release for 4 seconds
3. Upon release, all console led lights will turn on for 5 seconds.
4. If there are any failure codes, they will be displayed in the estimated time remaining display.
Note: this program recalls the most recent failure code first.
press the same key to advance to the next failure code.
(if the console doesn’t change then, the same failure
code was stored multiple times.)
if there aren’t any more failure codes, all the lights on the
console will turn on for 5 seconds.
Following this the washer will begin a diagnostic test, you may cancel if you wish by pressing the pause/cancel button.
Guest (10)
Kenmore front load washer 417.42142100 won’t do final spin. (Washer Repair)
by Kmeadows 5/28/2020 7:41:23 AM(UTC)
Kenmore Front Load Washer Suddenly Displaying 8E (Barely Used / Has not Been Used for a While) (Washer Repair)
by ataenter 10/30/2018 7:19:47 PM(UTC)
Kenmore Front Load Washer has power, lights, wont's start (Washer Repair)
by JJones35! 2/10/2017 1:53:12 PM(UTC)
kenmore front load washer won't spin (Washer Repair)
by kempffc 4/14/2015 1:34:35 PM(UTC)
Kenmore front load washer won't spin (Washer Repair)
by jwes 10/31/2014 4:31:29 PM(UTC)
Kenmore Front Load Washer (Washer Repair)
by sprank 10/3/2013 10:54:19 AM(UTC)
Kenmore Front load Washer 417.47102700 timer or Motor Control Board issue? (Washer Repair)
by BGM 2/8/2013 12:13:07 PM(UTC)
Kenmore front load washer dies before end of cycle. (Washer Repair)
by The Hobo 1/16/2013 5:10:50 AM(UTC)
by ERICJS112 5/8/2012 4:45:03 PM(UTC)
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 1/10/2012 2:27:09 PM(UTC)
Kenmore front load washer intermittantly fails to spin (Washer Repair)
by fivefoot20 11/28/2011 9:41:30 AM(UTC)
New Sears Kenmore Front Load Washer Power Button Broken (Washer Repair)
by CEDRIC_W 8/19/2011 11:53:45 AM(UTC)
Kenmore front load washer (Washer Repair)
by ajm1979 8/16/2011 1:08:02 PM(UTC)
Kenmore front load washer won't spin... (Washer Repair)
by carlymac 7/1/2011 2:00:03 PM(UTC)
Kenmore front load washer squeaks and makes horribly loud noise on final spin cycle (Washer Repair)
by pktrain 6/8/2011 10:55:26 AM(UTC)
2 Pages12>
