LakeRat1
#1 Posted : Wednesday, November 25, 2015 8:52:25 AM(UTC)
LakeRat1
We have a Viking Stove/Range >< one of the spark Module went out, it was the one that lights the 2 right hand & center Burners, >< the one I replaced it with Looked just like the old one, & I took off each wire and place it on the Correct post/lug >< all the burners will light
BUT when I light any of those 4 burners, the spark keeps going on all the 4 burners until we turn off the burner ><
thinking back it use to do this SOMETIMES with the old part, but after a while it would stop >< Can any of you point me in the right direction to fix this problem
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Old Hardwick Gas Range LP conversion and/or adjustment (Oven Repair (including Ranges and Cooktops))
by DaveLab 5/28/2024 2:53:48 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
Stuck bottom pan on gas range (Oven Repair (including Ranges and Cooktops))
by Guest 11/4/2023 12:02:07 PM(UTC)
Whirlpool Gas Range No Lights and Locked Door After Self-Clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 8:05:39 PM(UTC)
Gas Range Electrolux parts (Appliance Parts)
by becky97060 12/13/2022 11:07:33 AM(UTC)
Capri Gas Range Door won't close tightly (Oven Repair (including Ranges and Cooktops))
by Guest 5/26/2022 9:56:34 AM(UTC)
Maytag CRG7500AAW Gas Range (1995) access to spark module (Oven Repair (including Ranges and Cooktops))
by videobruce 4/10/2022 4:14:27 AM(UTC)
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
Gas Range - all four burners spark continuously if any one burner is lit (Oven Repair (including Ranges and Cooktops))
by eichsel 1/29/2022 7:48:44 AM(UTC)
Gas Range Burners Won't Stop Sparking (Oven Repair (including Ranges and Cooktops))
by eb5 12/7/2021 12:05:37 PM(UTC)
Samsung NX60T8711SS smart dial gas range (Oven Repair (including Ranges and Cooktops))
by bob4al 11/10/2021 2:16:51 AM(UTC)
Amana gas range turns off while baking (Oven Repair (including Ranges and Cooktops))
by Shhomemom 10/18/2021 2:11:00 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
