When I press bake then start to turn on the oven, it defaults to 350 degrees. I press the temp + button and nothing happens, however I can decrease the temperature by using the temp - button with no issues. However once I decrease the temperature, I order to get it back to 350 degrees I have to turn off the over and star over. Is this something easy and inexpensive to fix or am I better off buying a new appliance?
Here are your parts Parts for Whirlpool GW395LEPB00 Range - AppliancePartsPros.comSee the attachment for the tech sheet http://forum.appliancepa..._icons/editor/attach.gifIt sounds like that key is bad on the control panel (item 1 in section 02) Unfortunately they do not show the key/pinouts for the control panel so you cannot check it with a meter. Check that it is the only key that does not work. The reason for this is that keyboards often have common outputs that share a number of keys So if this is the only key than odds are high that it is just the panel that is bad. |
THIS FORUM IS DEAD!!!!!!! |
