ironhead1969
#1 Posted : Tuesday, November 10, 2015 9:32:58 AM(UTC)
ironhead1969
My dryer wasn't heating or running properly so I checked the high temp cutoff it was open, So I replaced the high temp cut out and the operating thermostat. I got the heat back but the timer wouldn't advance in any mode (timed or autosense) I replaced the timer and still no advance, It heats and dries perfectly but no joy on the timer I checked voltage with the dryer running and got 236 volts across the timer terminals. Anyone ever run into this?
#2 Posted : Tuesday, November 10, 2015 10:25:18 AM(UTC)
Parts for Roper RED4440VQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram
Since you get about 240 volts across the timer motor and it does not advance I would say that you have received a defective timer.
Also I would replace the hi-limit thermostat. It should have prevented the hi-limit cutoff from blowing.
Also I would check the heating coil to be sure that it is not grounded which is the most common cause of hi-limit thermostat and cutoff problems.
Unplug the unit and both wires from the heater.
Measure the heater, should be in the 8 to 12 ohm range.
Then measure from each side of the heater to it's case, both should be infinite ohms.
If not the heater is grounded and should be replaced
