When I set tempin top oven it immediately says its 245 degrees. After 5 minutes the buzzer rings that it is at the set temp. Not! It takes an extremely long time to get to heat up and then the I have to set it to say, 375 for a 350 temp
THIS FORUM IS DEAD!!!!!!! |
