crzyred59
#1 Posted : Sunday, October 25, 2015 3:05:35 PM(UTC)
crzyred59
When I set tempin top oven it immediately says its 245 degrees. After 5 minutes the buzzer rings that it is at the set temp. Not! It takes an extremely long time to get to heat up and then the I have to set it to say, 375 for a 350 temp
#2 Posted : Monday, October 26, 2015 6:06:40 AM(UTC)
Parts for Maytag MER6770AAB Range - AppliancePartsPros.com
Here is a manual.
You will ave to join the site and be logged in to be able to download it.
http://appliancejunk.com...wnloads;sa=view;down=390
Here is a link with info on the oven sensor.
Check out 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
First try removing power from the unit for a few minutes to see if it will reset.
If this does nothing remove power (flip the breaker off) and check the oven sensor with a meter.
If it is OK check both elements with a meter.
If OK , odds are that the control board is toast.
Note you may also need a new overlay as it looks to be peel and stick and the often get fuined trying to remove them from the old board.
