Joined: 10/25/2015(UTC) Posts: 1  Location: Cleveland Tn
Hello Everyone,
My wife and I's Kenmore Ultra Wash 3 started having problems:
Usage - Start it on Normal Wash
Symptoms:
1.) Not draining but I did check the check valve and it was clean and did not check the drainage hose.
2.) It will not progress past the Normal Wash stage - stays stuck there
If anyone has any recommendations we would really appreciate it cause neither my wife nor I are plumbers in any sense of the imagination!:confused::eek:
Thank you for your time and responding to my post.
Best, Edward :D
A model number would be helpful. Find your model number - AppliancePartsPros.comOn some units the cycle pauses until the water reaches a certain temperature. Try running a cycle that does not heat the water. It may be that glassware or rinse is what it is called |
THIS FORUM IS DEAD!!!!!!! |
