Ed%%%%
#1 Posted : Sunday, October 25, 2015 9:50:50 AM(UTC)
Ed%%%%
United States
Hello Everyone,
My wife and I's Kenmore Ultra Wash 3 started having problems:
Usage - Start it on Normal Wash
Symptoms:
1.) Not draining but I did check the check valve and it was clean and did not check the drainage hose.
2.) It will not progress past the Normal Wash stage - stays stuck there
If anyone has any recommendations we would really appreciate it cause neither my wife nor I are plumbers in any sense of the imagination!:confused::eek:
Thank you for your time and responding to my post.
Best,
Edward :D
#2 Posted : Monday, October 26, 2015 2:02:45 AM(UTC)
A model number would be helpful.
Find your model number - AppliancePartsPros.com
On some units the cycle pauses until the water reaches a certain temperature.
Try running a cycle that does not heat the water.
It may be that glassware or rinse is what it is called
