Frig and Freezer not cooling. Both fans working Compressor running fine. Replaced motherboard cleaned coils below frig not sure what there is left to do?
Correct model is a MFD2561HES
I cannot find any info on the given model number. Please check it.
The model number may not matter as it sounds like you have a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
If the compressor is running then the unit should be cooling. Your post suggests that you get no cooling at all so it is a sealed system problem. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman I cannot find any info on the given model number. Please check it.
If the compressor is running then the unit should be cooling. Your post suggests that you get no cooling at all so it is a sealed system problem. It is a maytag. see link for better description Parts for Maytag MFD2561HES Refrigerator - AppliancePartsPros.com
