thunderr
#1 Posted : Thursday, October 8, 2015 5:00:03 PM(UTC)
thunderr
Frig and Freezer not cooling. Both fans working Compressor running fine. Replaced motherboard cleaned coils below frig not sure what there is left to do?
Correct model is a MFD2561HES
#2 Posted : Friday, October 9, 2015 2:20:32 AM(UTC)
I cannot find any info on the given model number.
Please check it.
The model number may not matter as it sounds like you have a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
If the compressor is running then the unit should be cooling.
Your post suggests that you get no cooling at all so it is a sealed system problem.
thunderr
#3 Posted : Friday, October 9, 2015 9:15:59 AM(UTC)
thunderr
Please check it.
It is a maytag. see link for better description
Parts for Maytag MFD2561HES Refrigerator - AppliancePartsPros.com
Guest (4)
